This event occurs because the disable-port action is configured for a meter and the ingress traffic rate has exceeded the rate limit of the meter. The disable-port is one of the configurable out actions to be taken when the rate limit of the meter is exceeded with the "configure meter <meter-name> committed-rate ... out-actions" command
The out-of-profile status may be cleared using the "clear access-list meter <meter-name> out-of-profile" command. A review of the Meter configuration may be warranted.
Notice
Port %portString% disabled by Ingress meter %MeterName% because the traffic exceeded the configured rate.
| Name | Type |
| MeterName | String |
| portString | SlotPort |
